Winter is coming on so I'm putting the hardtop back on my '57 but having trouble getting the side guide pins to go into their receiving holes. The top is from a '60 but I'm not sure that should have a bearing the installation. There are two holes in the receiver plate and after much work, was able to get the guide pin one side seated. But the pin on the other side is positioned between the two holes and with the hardtop hold down bolts loosely in place & front guide pins unseated, am still not able to get it to budge forward or backwards to seat. I'm not sure which hole their supposed to seat into, however the right side did reluctantly go into the fwd hole. I'm hoping someone has experienced a similar problem and can offer an easy solution. Below is a picture of the pin and it's position between the receiving holes.
Gerry
Gerry
