1954 Corvette starting issues - NCRS Discussion Boards
  • Gerald A.
    • April 30, 1997
    • 45
    Have a 54 Vette, all stock, it will only start if I put a little gas in all 3 Carburetors. After that it starts and runs fine and will start again and again without adding gas to carbs. If it sits overnight I have to add gas again. Any advice is appreciated
    should have read starting issues in the title block, hate auto correct
  • Leif A.
    • August 31, 1997
    • 3646
    Re: 1954 Corvette starting issues
    Are you pulling out the manual choke before attempting to start?
    Leif
    • Gerald A.
      • April 30, 1997
      • 45
      Yes I have and the chokes all work well.
      • Bruce B.
        • May 31, 1996
        • 2930
        Do the old YH (?) carbs have accelerator pumps?
        • Chris S.
          • January 1, 2000
          • 1068
          is the fuel pump in good order ?
          carbs rebuilt ?
          1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
          Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
          1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
          1957 Corvette - FI 3 sp - Black and Silver
            • 15621
            Per the Advanced Judging Seminar given by Tim Ehlers at the recent Texas Regional the answer, Bruce, is no they do not. Tim stated it is essential to properly adjust the chokes because they must seal well enough to create vacuum which draws the fuel into the carburetor throat. I was hoping Tim would chime in on this thread because I am providing third hand information and I don't trust myself to be entirely up to speed on these details.
            • Chris S.
              • January 1, 2000
              • 1068
              Terry is very right - each one can be adjusted individually to closed all the way
              • Gerald A.
                • April 30, 1997
                • 45
                Thanks for all of your help, I found the problem. The accelerator pump springs are to week to return the pump to its proper position ar the top. It was going down but not returning when you let off the accelerator.
                • Tim E.
                  • April 1, 1993
                  • 360
                  As Terry described and Chris confirmed, all 3 choke plates need to be synchronized and need to fully close for easy starting. There is a "pump diaghragm" inside the carburetor which it is designed (based on vacuum) to enrich the mixture for acceleration. It does not squirt fuel into the venture like we're used to with later carbs. Tim
