Manifold vacuum fitting orientation- '70 LS5 - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4607
    Which way should the port on this fitting be pointed and its vacuum hose be routed? [IMG]file:///C:%5CUsers%5CMark%5CAppData%5CLocal%5CTemp%5Cmsoht mlclip1%5C01%5Cclip_image002.png[/IMG]
    The only reference I found in AIM was J50-A1 (the power brake section), but my car doesn't have PB.
    Currently, the port is at 4 o'clock (looking from above with the front at 12 o'clock) with its hose going between the two ignition cable brackets, then bending to the right to go along the center plenum panel ("firewall"), then to the reserve tank. The vacuum filter is over the rear of the right valve cover. See photo below. And yes, I know the fitting is incorrect and should have only one port.
    I saw a restored '70 LS5 top flight car at Frisco with its port at about 9 o'clock and the hose routed between the coil and left valve cover. Its vacuum filter was near the manifold fitting, under the air cleaner. I first saw this with the air cleaner removed but it was installed when I later took the photo below. Note that unlike my car, this one has PB. (Side bar: I just noticed that this car doesn't have an ignition cable bracket spot welded to the left valve cover. Interesting.)
    <Problem uploading photo>
    The hose routing on the top flight car is more direct and looks cleaner. But the longer hoses on my car look original and would be too long if rerouted like the top flight car. When I asked a couple judges at Frisco about this, they weren't sure.
    Anyone know what's TFP?
    Thanks folks!
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • 3419
    Re: Manifold vacuum fitting orientation- '70 LS5
    Hi Mark,
    I was looking through the LS5 thread on the CF hoping for some original engine pics and came upon your posts and your CAR!
    QUITE a nice looking paint job you did!
    A beauty!
    • Mark E.
      • April 1, 1993
      • 4607
      Thanks Alan. It's a lacquer job sprayed in my garage.
      For some reason, I cannot post the photo of the Top Flight '70 mentioned in my last post. I can upload other photos so the problem seems unique to that one. Odd.
      Anyway, as I described earlier, the manifold vacuum fitting on that car points to the left of the car (almost opposite of mine) with its hose routed between the ignition shielding and the rear of the left valve cover as it goes to the plenum (firewall).
      Any help understanding the proper routing of this hose is appreciated.
      Best,
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Mark E.
        • April 1, 1993
        • 4607
        The photo of my engine in the first post no longer appears for some reason. Here it is again:
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Kevin G.
          • February 1, 2005
          • 1077
          My 71 LS 5 has the fitting facing the same as the 70 you describe. About 180* different direction then your picture illustrates.
          • Mark E.
            • April 1, 1993
            • 4607
            Does your '71 have PB? I'm wondering if that makes a difference.
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Kevin G.
              • February 1, 2005
              • 1077
              Nope, no power anything.... Pure HP!
              • Mark E.
                • April 1, 1993
                • 4607
                And with our engine, pure torque. Reminds me of the old saying, "people buy HP, but drive torque".
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
                • Mark E.
                  • April 1, 1993
                  • 4607
                  So is there general agreement that for LS5 engines the manifold vacuum port going to the vacuum reserve tank points to the left side of the engine?
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
