My 235 engine from my '54 Vette has been bored +0.080 over.  It needs new rings, because there is some leak down beyond what the mechanic feels is acceptable even though the engine has excellent compression on all cylinders.  The crank and rod bearings and journals are in very good condition.  Should I just install rings, or should I have the cylinders sleeved and go with new pistons and rings?
The cam is shot. Journals and bearings are in good condition, but all we can figure is that the cam was installed/broken in improperly. Any help anybody could give me on sources for a cam and lifters; perhaps new valve springs, would be most appreciated.
Don Moses
Bayview, TX
For what it's worth, here is a pic of the stripped block...
Don Moses
Bayview, TX
