1954 general engine question - NCRS Discussion Boards
+ More Options
Posts
  • Guy M.
    • November 1, 1993
    • 500
    Can a f54yg use hydraulic lifters if someone wanted to and are the pushrods the same. Im just wondering. Thanks
    • 43259
    Re: 1954 general engine question
    Guy------
    I think you could but you can't use hydraulic lifters with the original camshaft. You would have to obtain a camshaft designed for hydraulic lifters.
    • Chris S.
      • January 1, 2000
      • 1068
      Yes you can with a new cam
      and yes they are QUIET .........
      1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
      Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
      1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
      1957 Corvette - FI 3 sp - Black and Silver
      • Guy M.
        • November 1, 1993
        • 500
        Thanks guys, I really appreciate it!!
        • Bill K.
          • November 1, 2003
          • 5
          1954CorvetteBlockDifferences.pdf
          Guy - I wrote this article a while back on the differences between the 3835911 block with hydraulic lifters used in passenger car & truck applications and the 3835911 block with solid lifters used in Corvettes. The difference is a 5/8" hole cross drilled from the back of the block through the lifter galley to facilitate oiling of the hydraulic lifters. See photos in the article.
          I would assume you need this cross drilled hole if you were to use hydraulic lifters in a real 3835911 Corvette block.
          Tim
          • Guy M.
            • November 1, 1993
            • 500
            Thanks Bill, that makes a big difference, so the moral to the story is that it wont work if I understand it. I was kicking around looking for an A, B ot C block to go with my C head but really didnt want the solid lifters but oh well.
