Re: 1959 Power Top System
All of my Plated parts are done. I may take a ride out to pick them up later. it's about a hour each way.
I cleaned up the armature commutator on my lathe. The new flat cleaned surface area will provide better contact and allow full current to pass to the pump system.
I cut in 3 minimal depth passes using my automatic horizontal feed to remove the minimal amount of copper to attain a smooth brush contact surface. I will bevel the brushes to the commutator later during assembly.
I then use 1500 grit paper on a flat backer plate to remove ridges. Then using the backside of a X-Acto blade and thin screwdriver I clean the gaps between segments. A final polishing back on the lathe with the 1500 grit finishes the task. I then did a polish of the shaft ends. Note thrust washers. Quantity can vary with different motors. Altogether this took a little over a hour but should rejuvenate the motor for best hydraulic pump operation.
