I am doing a frame off on a '67 with a Powerglide. Is there any way to tell if it is orginal to the car. I read the judging manual but it did not reference anything. The block stamp says Powerglide. Just wondering if the car serial # should be present and where.
1967 Powerglide transmission
Re: 1967 Powerglide transmission
According to the new judging manual, it says the pans have no drain plug, according my 1966 service manual, it says to drain the fluid, remove plug, so which is correct? If the error is in the judging guide then it should be changed. Would like to hear from Powerglide owners, plug or no plug.- Top
Thanks to Keith as well as other 67 M35 owners, including verification using GM documentation in the 1967 Chassis Service Manual, we recognize the error. A correction has been made noting the presence of a drain plug in the 1967 CTIM&JG 6th edition.- Top
Let us not get too carried away with "A correction has been made noting the presence of a drain plug".
A correction has been made noting the observed presence of a drain plug on some believed original pans is simply stated and nothing more.
No inference is made regarding factory stampings or configuration, nor should any further conclusions be drawn beyond that initial statement.- Top
