Antenna cable / rear harness routing - NCRS Discussion Boards
  • Jim B.
    • June 29, 2015
    • 53
    I am replacing the coax antenna cable on my '65 coupe. Just inboard and under the door sill there are two clips which retain a metal strip which I believe supports and retains the carpet. The cable runs under that strip. How are those clips released so I can remove the cable?
  • Bill W.
    • March 1, 1980
    • 2000
    Re: Antenna cable / rear harness routing
    Jim just push down on the lower part of the clip .
    • Jim B.
      • June 29, 2015
      • 53
      Thanks Bill... they are stiff little devices and don't release easily
      • Jim B.
        • June 29, 2015
        • 53
        Hi Bill
        Those clips released by doing just as you suggested. Now I am getting ready to reinstall that support strip back in those clips and I noticed that the strip has a notch cut into it slightly toward one end of the strip (not centered/symmetrical left-right). Does the notch go toward the front end of the car or toward the back end of the car? I don't really see why the notch is in there at all but I should have paid closer attention to the part as I was removing it. Thanks again for your help.
        Jim
        • Bill W.
          • March 1, 1980
          • 2000
          Jim the notch goes up . If you put some lube or dawn soap on the clips they will go on better .
          • Jim B.
            • June 29, 2015
            • 53
            Thanks Bill.... what is the purpose of that notch?
            Jim
            • Jim S.
              • March 13, 2013
              • 360
              Notch is for wiring for power window switch and/or neutral safety switch on automatics
              • Jim B.
                • June 29, 2015
                • 53
                Thanks Jim... what is the purpose of the sill plug just outboard of the wire cover strip and under the sill?
                • Jim S.
                  • March 13, 2013
                  • 360
                  If it were a roadster it's where a body bolt would go. Coupes do not have a body mount at that location so a plug is used.
                  • Jim B.
                    • June 29, 2015
                    • 53
                    ah ... thanks!
