Old License plate restoration - NCRS Discussion Boards
  • Jim S.
    • March 1, 1986
    • 1402
    I was getting very bored since it was now late September and the temp was still at 105 degrees here in Phoenix. So I decided to do a mostly indoor project while I waited for my garage to become workable.
    After several attempts , and trying various methods, I hit on one that gave me great results. It came out so good I had to share it with someone.
    I hope to have the other one done this week. Should coincide perfectly with the weather change that allows me to get back to work on the car .
    Jim
  • Mark E.
    • April 1, 1993
    • 4549
    Re: Old License plate restoration
    Beautiful result!
    Maybe your next project can be to add AC the garage...
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Ara G.
      • January 31, 2008
      • 1108
      Nice job! Well done.....
      • Jim S.
        • March 1, 1986
        • 1402
        Maybe your next project can be to add AC the garage...[/QUOTE]
        Thanks Mark,
        Trust me , I looked into that . By the time you buy the unit , run the duct work, insulated the ceiling , fur-out and insulate the block walls , and insulated or replace the 18 foot aluminum door that faces west , your at the price of a good used car !
        I settled for a portable Swamp Cooler . Works great until it hits 105 + outside ! Besides, if I had done that , I would only have a completed 66 corvette. Not these cool plates to hang on the wall !
        Jim
        • Domenic T.
          • January 29, 2010
          • 2452
          Jim, great job,
          I did a CA black & yellow and have to do a few more. I was warned that it is not legal to alter plates as in painting but got a smile from them.
          Had to have a DMV check and the plate looked toooo good. In restoration they cut us a lot of slack.
          Dom
          • Terry B.
            • December 1, 1988
            • 111
            So what is the secret for painting the numbers and letters?
            I have tried several methods and none worked satisfactory.
            • Jim S.
              • March 1, 1986
              • 1402
              Hi Dom,
              I used a CA black and yellow as one of my first test subjects. One of these days I will redo it , now that I have the process down pat.
              • Charles C.
                • July 25, 2012
                • 37
                Yes, please share your secret of painting the digits with us! Your blue plate looks very nice in the photo.
                I am currently restoring a pair of Ca black plates and have experimented with several methods. So far, rolling paint (with a hard roller) on to the digits has proved to produce the smoothest result. Taping and spraying was OK, but doesn't duplicate the OEM edge look as nice to me.
                I have several mint unfaded originals to compare my experiments to, but haven't come up with the right method to make me happy yet....
                Charlie
                Charlie C.
                Unrestored faded '67 Coupe Lynndale Blue, Black Leather
                Factory options: A01 C60 G81 J50 K66 L36 M21 N40 QB1 U69
                • Larry C.
                  • April 1, 1980
                  • 279
                  Yes, it would be nice for you to share your process. Or, do we have to beg first? Great job on the plates!
                  Larry
                  • Jim S.
                    • March 1, 1986
                    • 1402
                    Terry and Charlie,
                    What your asking of me is a really long answer . One I don't have time for right now. I will sit down tomorrow and try sort it all out in words.
                    Like both of you, I went through a lot of different methods . The one settled on still involves a lot of steps and tricks.
                    The quick answer however is I spray painted the characters first.
                    • Dan B.
                      • July 13, 2011
                      • 545
                      Nice result, please share your method with the group, experience is the best teacher
                      • Jim D.
                        • 2884
                        I've restored many plates and it's actually quite easy. I glass bead the plate and fix any dents/defects. Then primer and spray the main color. I use 3M 1/8" Fineline tape to outline the digits, finish masking the rest of the plate and then spray the digit color. The small letters etc. are done freehand with a pin striping brush. In Wa. State, they really don't care if you restore them or not as long as they are readable.
                        • Richard H.
                          • March 1, 1995
                          • 45
                          I have not done any this way, mind you, but I had researched and this is the method I'm going to try on the '57 plates I bought: After prepping all surfaces, spray the entire plate with the background color. After letting it dry sufficiently, cover the entire plate surface with masking tape. Then, take an orbital sander and while keeping it nice and flat, sand the masking tape off the numbers, letters, and any other raised areas. Then the letters and numbers are ready to spray or roll. Afterwards remove the rest of the tape, and you're done. This method sounded fairly quick and easy.
                          • Stuart F.
                            • August 31, 1996
                            • 4676
                            First; I have a collection of about 50 or 60 old plates (tags) and there are some I might like to restore including my original 63 Wisconsin plate from my Vette, as well as a number of my old plates from earlier year cars I have owned and later from Illinois, New Mexico and Florida so I am nterested to.
                            Second; I have been looking for perhaps an ex-con with experience who'll work cheap.
                            Stu Fox
                            • Domenic T.
                              • January 29, 2010
                              • 2452
                              Stu,
                              Great Idea, you would think with all the suggested counterfeit cars and so forth that we would have a X somewhere here on the forum!! Someone has to have some on the job training!
                              Dom
