I would like to ask a key question for a friend in my chapter. Is the ignition key removable when the motor is running??and secondly do all doors,ignition,glove box and tire lock keyed alike ??
63 Ignition Key
Re: 63 Ignition Key
Yes. The owners manual explains it quite well. Shouldn't come out of ignition switch in the off or acc position, only in on and lock. Same key for all locks.1964 Red FI Coupe, DUNTOV '09
Drove the 64 over 5000 miles to three Regionals and the San Jose National, one dust storm and 40 lbs of bugs!- Top
Re: 63 Ignition Key
Enzo, There is one key for everything for 63 and I believe the key is removable when running and there is only one position that locks the switch as It says on the instrument cluster.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
Re: 63 Ignition Key
Enzo, if it doesn't work that way you may have the incorrect ignition lock installed. I believe 63 was a one year one lock I believe it had 435 embossed on the side.
Re: 63 Ignition Key
That sounds right - the same key should unlock the spare tire tub lock...- Top
Re: 63 Ignition Key
The biggest problem I see is the key can be pulled out in the 'off' position. If it can, the tumblers are worn and need renewed. 63/64 same switch, part number.1964 Red FI Coupe, DUNTOV '09
Re: 63 Ignition Key
It's possible that the key is excessively worn, or that the lock wafers are excessively worn, or that both are worn. The easiest thing to do is to get a new key cut to the code and see if that fixes the problem. The key blank doesn't need to be an expensive NOS blank. Just a new key cut properly to the key code. Obviously you don't want to just have a copy made of a worn key.
Gary- Top
Re: 63 Ignition Key
The original Delco-Remy ignition switch for the 1963 Corvette was p/n 1116635 & is embossed "635". This switch was also OE on the 1964 Corvette.
The Chevrolet Parts History, Revised January 1, 1973 lists "1116635 USE 1116650 07-66". Pete- Top
Re: 63 Ignition Key
After thousand of repeated clockwise rotations, the internals of the 63 ignition lock tend to become permanently rotated slightly out of its designed alignment. This slight misalignment allows the key to come out when it looks like it's in the 'off' position, because the internals are really more aligned with the 'lock' position. While you can't force the ignition back to its original alignment, you can trick the ignition into working like its properly aligned.
Remove the lock and study its operation. While it's difficult to explain here, you will find that by putting a bit of JB Weld in the proper location and filing it to the proper shape, it will work as designed.Last edited by Michael G.; October 16, 2015, 02:23 PM.Mike
1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.- Top
