C3 Seat to Floor Bolts... Grade 5? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4552
    In 1970, what grade bolt is used to attach the seat to the floor (4 bolts per seat)?
    The replacement bolts I purchased are grade 5 (3 radial lines on the head). Given how important these bolts are for safety, I was wondering if they should be grade 8.
    The bolts I removed don't match, so they're not a good reference.
    Thank you!
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Gene M.
    • April 1, 1985
    • 4232
    Re: C3 Seat to Floor Bolts... Grade 5?
    The indented head black phosphate finish grade 5 (3 radial lines on the head) are correct.
    • Mark E.
      • April 1, 1993
      • 4552
      Thanks Gene. Grade 8 is probably overkill when it's just bolted to fiberglass.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Leif A.
        • August 31, 1997
        • 3631
        Mark,
        Just to clarify...the seat track bolts pass thru the fiberglass floor pan and are threaded thru nut plates attached to the fiberglass flooring. They are NOT bolted to the fiberglass.
        Leif
        • Mark E.
          • April 1, 1993
          • 4552
          I understand Leif.
          My point is that the weak link in the attachment of the seat to the car is the fiberglass floor (via a small reinforcement plate). I suspect when force is applied (like during an accident), the fiberglass floor will fail first, not the bolt (or plate).
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
