Sticky Stuff - NCRS Discussion Boards
Sticky Stuff
  • Rey S.
    • April 1, 1995
    • 277
    Sticky Stuff
    The glued on vinyl surface surrounding the speedometer and tachometer is in OK condition as is the passenger side so I am trying to salvage them. What type of adhesive will do the job to glue down the edges and not come loose with interior heat as in parked in the hot sun?
    Thanks Rey
  • Eric F.
    • June 30, 2003
    • 319
    Re: Sticky Stuff
    Use of a good quality contact cement will do it. Be careful in the application and take your time. Make sure to remove the old adhesive or your vinyl may be lumpy.
      • 6960
      Re: Sticky Stuff
      Ray, To add to Eric's response use a heat gun or hair dryer to warm up the vinyl to soften.
