Seat belt warning buzzer harness - NCRS Discussion Boards
  • Jeff Y.
    • March 10, 2008
    • 73
    I think I found the right connector for the seat belt buzzer but it looks like part is missing. Where does the other half of the connection to the buzzer come from? See the picture attached.
  • Jeff Y.
    • March 10, 2008
    • 73
    Re: Seat belt warning buzzer harness
    Ok, so I've convinced myself that this is the TCS relay connector. Not a buzzer connection. My car is an early (Nov 71) car with a 15 second timer on the seatbelt light. Could it be that there shouldn't be a seatbelt buzzer? Which is why I can't find a connector for it?
    • Tom L.
      • October 17, 2006
      • 1439
      I'm pretty sure that my earlier build '72 only has the light operated by the timer. Either that or my buzzer is broken
      • Dan A.
        • February 1, 2004
        • 212
        Your car would have been built before the seat belt buzzer. It has only a timer, as you suspected. It is located behind the the right hand dash panel and attaches to the cowl.
        • Jeff Y.
          • March 10, 2008
          • 73
          Thanks Dan.
          • Mark E.
            • April 1, 1993
            • 4600
            Does this seat belt light timer replace the manual push button to turn off the light used in 1970 (and maybe earlier)?
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Jimmy P.
              • June 24, 2014
              • 1696
              Yes Mark, the manual push button was gone on the 72 - 73. The early 72's had about a 15 second timer that shuts out the light. On the later 72's the light and buzzer went off only after the seatbelt was extended or the parking brake was applied.
              Jimmy
              1973 Convertible
              L48,M20,N40
              Mille Miglia Red/Oxblood
              • Mark E.
                • April 1, 1993
                • 4600
                I always thought it was silly to have a button on the dash to turn off a seat belt reminder light.
                Mark Edmondson
                Dallas, Texas
                Texas Chapter
