Well it's been a long summer. Now that it's cooling off I finally got my A/C working properly. It not that there were many failures in the process, my boss (my wife) changes my priorities now and again.
Anyway, Starting in the spring I removed all the A/C components between the evaporator and the condenser.
There are many I's in this but it feels good to do it yourself!
I sent the compressor to one of our own for a rebuild. He did a great job.
I rebuilt the STV
I found a period correct expansion valve that tested correct, the original was jammed shut.
I found correct Freon hoses and had them dated
I flushed the evaporator
I flushed the condenser
I obtained all new green O-rings
I obtained a 30 lb tank of R12
I obtained 2 qts of R12 oil
The drier was Ok.....
I installed all the components using the green O-rings soaked in R12 oil. Took about 10 hours as there is no space to work. Last part in was the drier.
Since I don't have the tools, I took it to my buddies shop and it passed the Vacuum test. Good job on my part.
He also charged the system with R12 and it's now blowing at 40 degrees. Just in time for winter.
Hopefully in the spring it will be just fine.
You can do it yourself.
Good Luck
I rebuilt the STV
Good Luck
