I got misfiring problems in my 1966 327 300hp car. In order to locate which cylinder have the misfiring issue, I disconnected each ignition cable at the distributor cap. When I pulled the cable for cylinders 1, 4, 6 and 7 it effected the engine idle. When I pulled the cable for cylinder 8, 3, 5, and 2, it had no effect on the idle even though I could see a spark when moving the cable close to its position in the cap. According to the firing order, this means that every other cylinder have a misfiring problem.
Does anyone have a clue on what could cause this misfiring pattern?
Thanks for any idea!
