Differential mounting - NCRS Discussion Boards
  • Michael G.
    • November 12, 2008
    • 2158
    Would some please post a pic of the front mount of the 63 differential? The AIM is not too clear and I can't remember which cushion goes where. If I had my other car here, or my computer with pics of the entire chassis, all would be clear, but I don't, so its a bit fuzzy...
    Mike
  • Edward J.
    • September 15, 2008
    • 6956
    Re: Differential mounting
    Mike, not good at posting pic. here, but the rubbers are sandwiched between the frame, and big washer, lock washer, and nut go on the bottom of diff. mounting bracket.
    • Joe R.
      • July 31, 1976
      • 4552
      Michael,
      Hope this helps.
        • 43277
        Mike------
        Maybe this page from the 1979 AIM will show it more clearly. The installation and the parts are exactly the same for 1979 as for 1963. The upper cushion, GM #3788637 and applicable to 1963 through 1979, is still available from GM. The lower cushion, GM #3795333 and applicable to 1963 through through 1982, is discontinued.
        • Michael G.
          • November 12, 2008
          • 2158
          Thanks guys, all good now
          Mike
