help on 64' coupe - NCRS Discussion Boards
help on 64' coupe
  • John D.
    Infrequent User
    • July 31, 1996
    • 23
    help on 64' coupe
    want to paint a section of a 64' air cleaner base, the color is gloss black but does corvette have a paint code etc for the air cleaner base. What is the best way of matching the color. HELP is appreciated. Thanks
  • Dan H.
    • July 31, 1977
    • 1372
    Re: help on 64' coupe
    John, believe the air cleaner was painted by supplier, AC. I've used and like quantas gloss black, seems to age and look good as time passes. Don't get too glossy, sure AC didn't.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • John D.
      Infrequent User
      • July 31, 1996
      • 23
      Thanks for reply. JD
        • 6957
        John, I would try a semi gloss test panel and gloss to see which matches the best, sometimes with the semi gloss a light polishing compound will give you the look you want.
        • John D.
          Infrequent User
          • July 31, 1996
          • 23
          Ed, thank for the info it's appreciated, JD
