67 Tire Jack - NCRS Discussion Boards
67 Tire Jack
  • Enzo C.
    • January 12, 2012
    • 534
    67 Tire Jack
    Gents, I am looking for the correct photo's and description for a 1967 E7 tire jack... Are any available ??? Does anybody restore these ??? thanks
    Enzo Colosimo
    Ncrs Ontario Chapter Chairman 🇨🇦
    ENZ-Z06/67
  • Stephen L.
    • May 31, 1984
    • 3162
    Re: 67 Tire Jack
    Here are before and after photos of my 67 original jack....... Not much to a restoration.... take it apart, bead blast, paint, and reassemble.
    • Daniel Y.
      • September 30, 2002
      • 185
      Re: 67 Tire Jack
      the washers were put on after painting - they should be natural
      Dan Young
      65, 67 Duntov x2
      66 bowtie x 2
      71 LT1 TF
      90 ZR1 McCelland
      03 Anniverary
      06 Z06
      • Gene M.
        • April 1, 1985
        • 4232
        Re: 67 Tire Jack
        Excellent point of detail. One would assume the jack lead screw was finished separate from the rest of the jack, then assembled.
        • Stephen L.
          • May 31, 1984
          • 3162
          Re: 67 Tire Jack
          Daniel and Gene, if you look closely at the photos I provided, you'll see that the nylon washer is indeed natural and the lead screw is only partially painted, just like it was before I took it apart.
          • Daniel E.
            • April 30, 2005
            • 145
            Re: 67 Tire Jack
            Original jack from my late May 67 car (see this thread for date code info: https://www.forums.ncrs.org/showthre...67-jack-dating )
            • Ara G.
              • January 31, 2008
              • 1108
              Re: 67 Tire Jack
              Steve, I think Dan is referring to the steel washers being natural as well as the nylon washer being unpainted.
              • Leif A.
                • August 31, 1997
                • 3645
                Re: 67 Tire Jack
                From the 5th edition TIM&JG.
                Leif
                • Stephen L.
                  • May 31, 1984
                  • 3162
                  Re: 67 Tire Jack
                  All, Thanks for pointing out the details of the metal washers, my mistake. I missed that detail when I restored my jack, it was some time ago and the newest manual was not out (which, by the way, is a great manual with many photos). My photo "before restoration" does show the metal washers to be "not painted". I'll need to correct that detail.
                  • Nick C.
                    • August 31, 1998
                    • 542
                    Re: 67 Tire Jack
                    Additional research and reports from original owners have prompted us to further revise 1967 jack descriptions. The following revisions have been made in the as yet unreleased 6th edition of the 1967 CTIM&JG:
                    1.) Jack dating has been observed on some original jacks from beginning of production
                    2.) approximately 30% of jack wrench heads do not display the cast O
                    3.) concentric circles on rivets are found on most but not all jack and wrench assemblies
                    • R N.
                      • May 31, 2002
                      • 640
                      Re: 67 Tire Jack
                      Nick, THANK YOU for sharing this knowledge and keeping us current!
