how many ounces of R134A to add to a C3 Corvette with a retrofitted system - NCRS Discussion Boards
  • Christopher R.
    • April 30, 2013
    • 65
    I have retrofitted the R12 system and converted it to a R134A but I still have the original factory compressor. All of the support i have seen says you don't need as much R134a as stated on the R12 sticker. Anyone have an idea of how many ounces to put in from a dry system?
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: how many ounces of R134A to add to a C3 Corvette with a retrofitted system
    May not help but just changed the 134 in my truck and it took 1# 6 oz.
    Lyle
    • Jim T.
      • March 1, 1993
      • 5351
      Lyle, My 1996 Corvette lists 2 pounds of 134 to charge the air conditioning system on my 1996 Corvette. My 1970 Corvette with factory air the use capacity is listed at 3 pounds and 4 ounces.
      • Joe C.
        • August 31, 1999
        • 4598
        A Google search yielded the standard rule of thumb as .8 lb 134a for each pound of R12 originally used to fill the original system
        I have an 87 300E and it normally takes 2.4 lbs of R12 to charge the AC in these cars. I have been told verbally by a good mechanic at an MB dealer to
        • Reiner O.
          • April 14, 2015
          • 16
          As Joe said, I own a repair facility and back when we did a bizilloin R134 conversions the manufacturers recommended 80% of the R12 charge
          • Robert B.
            • May 20, 2013
            • 39
            The 80% is a good number but if you are using manifold gauges (and I hope you are) pay more attention to the pressure readings than the weight. Get a chart for your application and charge to that. Likely that you will be right about at the 80% number when done.
