1972 Corvette with Vacuum leak at the headlight switch - NCRS Discussion Boards
  • Christopher R.
    • April 30, 2013
    • 65
    After completing the installation of entirely new wiring for my entire corvette project and getting all of the electrics to work, I now have to chase Vacuum issues. I have a new headlight switch and when I switch on the headlights, the headlights work, dash lights work and dim properly, but there appears to be a vacuum leak (quite noticeable noise wise) at the switch when fully engaged. Along with the replacing the electrics (and being the car has been restored) all of the vacuum components (hoses and actuators) have been replaced as well.
    Any suggestions (aside from a potentially cheap switch) that would trigger a large vacuum leak at the switch even when the hoses are new and appear to be tight? Maybe the hoses are backwards at the switch????
  • Gary S.
    • July 31, 1992
    • 1633
    Re: 1972 Corvette with Vacuum leak at the headlight switch
    If this is a duplicate, ignore it. My first reply vanished, it seems.
    Try this
    And this
    • Christopher R.
      • April 30, 2013
      • 65
      thanks, I printed that and will watch the video tonight. This next question may sound crazy, but if you cannot get a good seal around a fitting even after cutting the hose to get to attempt a tight seal does a small amount of adhesive aid that situation.
        • 11668
        Sometimes I will wrap a small amount of self-adhesive tape around the port before trying to attach the hose. The tape makes the port effectively larger so it will seal.
        Of course, the cause is the cheap switch, which is why originals are much nicer.
        • Michael W.
          • April 1, 1997
          • 4290
          Are you sure you're hearing a leak at the switch and it's not actually the sound of air flowing through the switch? If there's a serious leak elsewhere in the system, the switch will sound quite noisy.
            • 3416
            Hi Chris,
            Do you have the hoses connected to the proper port?
            The 71 AIM is known to be incorrect and leads to a constant hiss at the switch. (Was it corrected for the 72 AIM?)
            The blue striped hose should be connected to the forward nipple on the switch as installed.
            On original hoses sometimes cutting about 3/8"-1/2" off the end of the hose improves it's ability to seal.
            Maybe?
            • Christopher R.
              • April 30, 2013
              • 65
              thanks I will try check those suggestions and let you know.
