Frame stamp - NCRS Discussion Boards
Frame stamp
  • Justin S.
    • July 3, 2013
    • 305
    Frame stamp
    Upon prepping my frame for paint I found a stamped -10 inside of a circle. It's on the top side of the differential cross member. I can't figure out how to attach pictures on the mobile site.
    Also, is it recommended that I clean the frame with a degreaser or mineral spirits before painting?
    Thanks, Justin
  • Lawrence M.
    • February 1, 1995
    • 404
    Re: Frame stamp
    Hi Justin,
    I have found the same marking on the frame of my December built 1969. I do not know what it means, but I do not think it is anything special. Maybe an inspection stamp ?
    Larry
    2002 Z51 Convertible
    1969 L46 Convertible
      • 43281
      Re: Frame stamp
      Thanks, Justin
      Justin-------
      A VERY, VERY common stamping seen on Corvette frames.
        Re: Frame stamp
        Dana Corp. was the supplier of the Corvette differential crossmember, and they stamped "-10" on every one of them.
        • Jim S.
          • March 13, 2013
          • 360
          Re: Frame stamp
          Justin, I assume the frame has been media blasted? If so, use compressed air to clean it well and whiping with something like Prep-sol to remove any grease or fingerprints would be a good idea.
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11364
            Re: Frame stamp
            A few reference photos....
