C2 (1966) Strut Rod install - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2586
    This related to a basically bare frame. I have installed the front suspension and started install the rear suspension. I installed the rebuilt trailing arms, differential, and leaf springs.
    My question is, can I install the strut rods or should I wait for more weight on the chassis?
    With the springs installed and very little weight on them, they push the trailing arms down to a point where the strut rod mounts are very much out of alignment with the strut rod mount points on the bracket under the differential. I will need to use a ratchet strap or something similar to pull the trailing arm up so that I can get both ends of the strut rods in place.
    My concern is the torque this will be placing on the strut rod bushing and that it could and likely will sit this way for a few months.
    Would it be better to wait until I have the engine, trans, and body back on the car, or am I worrying about nothing?
    Don
    Don Harris
    Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
  • Jim S.
    • March 13, 2013
    • 360
    Re: C2 (1966) Strut Rod install
    Don
    I would have suggested installing the strut rods BEFORE installing the leaf spring Is it too late for you to unbolt the spring ends, install the strut rods, and re-bolt the leaf spring?
    • Donald H.
      • November 2, 2009
      • 2586
      That would have been easier, but doesn't address my concern. If I had installed the strut rods first, then the spring, the spring tension would still put a lot of twist/torque on the strut rod bushings. I just don't know if this twist/torque will harm the strut rod bushing
      Don Harris
      • Jim S.
        • March 13, 2013
        • 360
        Shouldn't hurt anything.
          • 43248
          Don------
          As long as you don't tighten the nuts on fasteners on each end of the strut rods, there should be no problems created for the bushings. Yes, there will be some "unusual compression" of the bushings but it should not harm them in any way. You should not tighten ANY of the suspension fasteners until the full weight of the car is on the suspension AND the suspension is normalized.
          • Donald H.
            • November 2, 2009
            • 2586
            Don
            Don Harris
