I'm to the point I'm rewiring the car, just about to marry the body back to the frame and paint. I'm running the various harnesses and wondered about the choke heater and idle stop solenoid on the carb. The car didn't have wiring for these when I got it, but it was a tad molested too.
Page 12H of the AIM for 1980 shows a harness coming from the forward lamp harness (runs juxtaposed with the alternator wiring), but it indicates the connection is for RPO's LG4 and NB2 (basically the California 305 and California emissions). I need to verify my repro forward lamp harness does or does not have a connector for this carb harness. That would kill it right there if it didn't (since I ordered the non-CA harness).
In any case, I take from this that the car wasn't shipped with wiring in place since it's a non-CA L48 (350). I find it a bit odd that GM would add the solenoid to the carb for all 1980 cars, yet make a connection only for LG4 cars. Doesn't seem cost effective, and we all know how they did try to be cost effective. (The paint on this car shows that if nothing else...
) I'm sure the carb is original (evidence: P/N and date code).
I don't find any aftermarket repro's of this harness, so even if I wanted to install it, I'd have to hunt down the proper connectors and guess the wire colors (the two wiring diagrams I have don't show this harness but do show the ECM wiring, so I'd key off of that if I had to). The AIM doesn't give a part number, so I can't search that way.
I'm thinking I'm good to go with not worrying about the carb electrical, even with the cold engine start being a bit cold-blooded. Runs fine warmed up...dunno about C60 ops yet as that's not installed at present (body drop must occur first).
Any judges of 1980 cars know any details? My logic/suspicion is correct? Not correct?
) I'm sure the carb is original (evidence: P/N and date code).I don't find any aftermarket repro's of this harness, so even if I wanted to install it, I'd have to hunt down the proper connectors and guess the wire colors (the two wiring diagrams I have don't show this harness but do show the ECM wiring, so I'd key off of that if I had to). The AIM doesn't give a part number, so I can't search that way.
But at least it's squared away and maybe helpful to someone in the future... Thanks all...
