1954 Carb popping - NCRS Discussion Boards
1954 Carb popping
  • Ted K.
    • August 31, 1994
    • 337
    1954 Carb popping
    A good running 1954 with everything pretty close to specs. When under acceleration or racing up the engine from under the hood there is a popping sound that comes from the rear carb.
    Any ideas???
    Ted
  • Chris S.
    • January 1, 2000
    • 1068
    Re: 1954 Carb popping
    check /adjust your mixture screw - on top - or check for a vac leak
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
      • 6950
      Any ideas???
      Ted
      Ted is it possible you may have a valve adjusted to tight?? maybe on one of the last two cylinders.
      • Ted K.
        • August 31, 1994
        • 337
        It idles pretty smooth so I wouldn't think a tight valve, but what else is there. I will check it out.
        • Ed S.
          • August 6, 2014
          • 1377
          Correct me if I am wrong but the only way you can get popping back through the intake system (in this case a carburetor) is for combustion pressure to be vented via an open or partially open intake valve. You indicate that a) you are confident of the adjustment and b) it happens when accelerating (I assume higher RPM ranges). A weak or incorrect valve spring will allow a valve (or valves) to "float" - to remain partially open at higher RPMs - this would allow for the popping noise you are hearing. At normal or lower rpm ranges they work perfectly - it is only until you get up into higher RPM ranges that the springs will fail to do their job - that is - force the lifter to "follow" the cam lobe and at the same time allow the valve to close properly.
          Ed
          • Ken A.
            • July 31, 1986
            • 929
            Pull the valve cover & check for a broken valve spring. If OK run a compression check. Sometimes you can reseat a valve with a good "whack"
            using a brass hammer.
            • Ted K.
              • August 31, 1994
              • 337
              Good information. Going to be out of the loop for a few days, but will let you know what I find.
