63 Air conditioning - NCRS Discussion Boards
63 Air conditioning
  • Michael G.
    • November 12, 2008
    • 2158
    63 Air conditioning
    Does anyone have a pic showing the belt and pulley arrangement used on the 63, when it had both air-conditioning and power steering? It might have been the same as later C2 cars (?), so those would probably be OK too.
    Mike
    1965 Black Ext / Silver Int. Coupe, L84 Duntov, French Lick, 2023 - Triple Diamond
    1965 Red Ext / White & Red Int. Conv. - 327/250 AC Regional Top Flight.
    • 6960
    Re: 63 Air conditioning
    Mike, have you checked the AIM for a pic. if not send Harry Sadlock a PM he has a 63 A/C car.
    • Michael G.
      • November 12, 2008
      • 2158
      Ed, unfortunately the 63 AIM doesn't show the belt system for the combination of AC and PS. I think I've ascertained that when the two options were ordered together, the AC and alternator belts remained as they are normally, but a third pulley was added to the crank for a belt that handled the PS only.
      Mike
        • 43291
        Michael------
        That's how it was. A pulley of GM #3751232 was "sandwiched" onto the existing 2 groove crank pulley. A power steering pump pulley of GM #3770509 was used. A belt ran between these two with the adjustment at the p/s pump brackets.
        • Michael G.
          • November 12, 2008
          • 2158
          Thanks Joe, I found a 67 with PS and AC for sale on ebay with some good engine pics
          Mike
            • 43291
            Mike-------
            If the 1967 configuration for either 300 HP or L-79 with C-60 and N-40 was the same as 1963 250/300 HP with C-60 and N-40.
            • Michael G.
              • November 12, 2008
              • 2158
              Joe, this is the 67 pic. I think, from what I gleaned from the 63 AIM, that this is what the 63 looked like too. Looks like a triple groove on the crank, with the PS pump on the outermost, the AC compressor in the middle, and the alternator in the inside..
              Mike
                • 43291
                [ATTACH=CONFIG]64431[/ATTACH]
                Mike------
                It's not a triple groove crank pulley. It's a double groove with a single groove "sandwiched" on the front. No Corvette small block ever used a triple groove crank pulley.
                • Michael G.
                  • November 12, 2008
                  • 2158
                  Thanks Joe.
                  Mike
