Re: 73 Headlights cutting out while driving?
Hi Jimmy,
If the bulb is not coming on, it is not drawing current, therefore it is not helping to cause the circuit breaker to pop. I don't know the pinout on your connectors, but assuming 12 V and ground are present at the connector, if you duplicate that on the bench, the lamp should light up. Do you know the GM part number of the switch? If you punch that into the search engine here it may give you how many amps the circuit breaker is rated at.
Joe
Hi Jimmy,
Joe
