1958 generator mount - NCRS Discussion Boards
  • Benjamin C.
    • July 31, 1994
    • 134
    Does the 58 have a four hole flat bracket mounted to the manifold or does the U bracket bolt directly to the manifold? The car is fuel injected. This is a very early car with right side hood support
  • Dan H.
    • July 31, 1977
    • 1372
    Re: 1958 generator mount
    The U bracket should bolt directly to the manifold, there is a heat shield for it. Be careful the fan belt clears the bottom radiator hose. Chevrolet used a mickey mouse fix, they pulled the Lower radiator hose back against the fuel line with a radiator clamp for fan belt clearance. Very early 58s had the RH motor mount ball peened for fan belt clearance, later 58s had a depression made in the mount.
    Dan
    1964 Red FI Coupe, DUNTOV '09
    • Richard M.
      Super Moderator
      • August 31, 1988
      • 11356
      FYI a document and more info in these threads....
      https://www.forums.ncrs.org/showthre...729#post730729
      The pdf I wrote has some info relative to the '58 FI bracket in Addendum A
      Post #10 in this thread a while ago has Dan's awesome document enclosed which may help.
      https://www.forums.ncrs.org/showthre...986#post729986
      Rich
