Leaking Front Seal R4 Compressor - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    Who will do the job right. Don't care about cosmetics.
    Shaft is pitted.
  • Leif A.
    • August 31, 1997
    • 3636
    Re: Leaking Front Seal R4 Compressor
    [QUOTE=Joe Ciaravino (32899);754294]Who will do the job right. Don't care about cosmetics.
    Shaft is pitted.[/QUO
    Joe,
    Domenic Tallarita is the noted specialist.
    Leif
      • 43242
      Shaft is pitted.
      Joe------
      Since you don't care about cosmetics, are you aware that bolt-on NEW A6 compressors are available? Some use a cast iron housing, as-original. Some use an aluminum housing (like modern compressors).
      If you decide to rebuild the compressor, here's an NOS shaft:
      • Joe C.
        • August 31, 1999
        • 4598
        Thank you Leif and Joe.
        • Michael H.
          • December 1, 1987
          • 730
          I end up buying a new A6 compressor and never had a problem with it.
          Mike
