Correct Oil Pan Drain Plug Location on a 73 L48? - NCRS Discussion Boards
  • Jimmy P.
    • June 24, 2014
    • 1696
    My L48 oil pan drain plug is located in the rear center. I don't think my pan was replaced. However, the 73-74 JM says the drain plug is located on the driver's side on the L48 and L82 cars, and the plug is located in the rear on the LS4. Is the manual in error or is my pan not correct?
    Jimmy
    1973 Convertible
    L48,M20,N40
    Mille Miglia Red/Oxblood
  • Russ S.
    • April 30, 1982
    • 2163
    Re: Correct Oil Pan Drain Plug Location on a 73 L48?
    The manual is incorrect. Plug should be center rear.
    • Jimmy P.
      • June 24, 2014
      • 1696
      Thank you Russ.
      is it also in the center for the L82?
      Jimmy
      1973 Convertible
      L48,M20,N40
      • Russ S.
        • April 30, 1982
        • 2163
        Yes Jimmy. It is.
        Originally posted by Jimmy Patitucci (60161)
        Thank you Russ.
          • 43247
          Thank you Russ.
          Jimmy------
          Center rear for ALL 1963-74 Corvette small blocks---every single one ever built.
          • Jimmy P.
            • June 24, 2014
            • 1696
            Thank you Joe,
            So the JM has these reversed?
            Then all LS4's drain plugs should all be on the driver's side of the pan?
            Jimmy
            1973 Convertible
            L48,M20,N40
            • Russ S.
              • April 30, 1982
              • 2163
              Jimmy, My 74 LS4 is center rear also.
              Thank you Joe,
              • Jimmy P.
                • June 24, 2014
                • 1696
                Thanks again Russ and Joe for clarifying this for me and for sharing your wealth of knowledge. Made notes of these corrections (along with the BB & SB dip stick clarifications from another post) in my judging manual. Hope it won't be an issue in the spring when I plan to have the car judged at our chapter meet.
                Jimmy
                1973 Convertible
                L48,M20,N40
                  • 43247
                  Thank you Joe,
                  Jimmie-------
                  No Corvette big block ever used an oil pan with a side drain. None. Other Chevrolet models with big block did, though.
                  • Russ S.
                    • April 30, 1982
                    • 2163
                    The 73-74 judging guide is very old so it will most likely be an issue at a chapter meet along with other items.
                    • Mark E.
                      • April 1, 1993
                      • 4600
                      So it sounds like we're saying all '63-74 Corvettes, small block and big block, had rear facing oil drain plugs.
                      Mark Edmondson
                      Dallas, Texas
                      Texas Chapter
                        • 43247
                        Mark-------
                        Yup, that's how it is.
                        From 1963-96 only the following used a side oil drain:
                        1) All 1975-79
                        2 1990-95 ZR1
