Hi there Can ANYONE Post or email me a PIX of PAGE F296 from C60 1966 AIM or even 65 or 67 Mine was never Copied in the AIM I have and I need to see where Drivers side Fresh Air Vent Cable Routes.......I have an Old Cable BUT dont know if its Correct...A/C Driver Cable Repos are WAY LONGER and Non A/C Drivers are Too Shor When Mounted to the Pass Position.. HELP please.. Thanks
Missing Page 66 AIM A/C C60
Re: Missing Page 66 AIM A/C C60
Neil-------
I don't know how much good these are going to do you, but here they are:
1966AIMpage295 001.jpg1966AIMpg296 001.jpgIn Appreciation of John Hinckley- Top
A very difficult topic to describe. AFAIK there is no sheet in the '64-6 AIM's that show the left kick-pad vent cable installed on a car with C60. Going through the GM parts books, it appears (by default) that the cable being discussed is part # 3874732, with description "air vent control (41_3/4" O.L.).
This compares with the non-air LH kick pad cable #3874729, which is described as "left (vent control) (22_1/8" O.L.)".
The extra length on the C60 LH vent cable [knob just to the right of the steering column, where the RH vent cable would be located on a non-air car] allows it to swoop upward, over the steering column and clutch bracket/rod, touches the insulation on the firewall, turns back toward the light switch then curves down and forward towards the final destination at the kick pad vent grille.Last edited by Wayne M.; September 13, 2015, 11:40 AM. Reason: added location of pull knob on cluster- Top
Neil -- No; the closest those 2 cables come to each other is about 5 inches. I'd take pictures but it's too congested under there.
P.S. I edited my post to revise/include some more description.- Top
Well that'll teach me not to remove page(s) from my copy of the AIM then forget to put back
. Cable under discussion shows on 1965 AIM, UPC C60, Sheet E7. And it shows the clip holding the LH kick panel cable AND the hood release cable. Well, I got the part # right anyway
, so the length mentioned is correct.
I still don't see how (after the clip) there is enough room or flexibility to pull a 90 degree turn then a 180 to connect with the vent door.
Somebody else with a '66 air car should report so as to get more examples.- Top
Routed as you said Up and over Steering and Clutch Bracket towards firewall before returning to Drivers Side and curved down to Attatch to Vent Grill... No way any Hood Release to Vent Cable Clip is going as as stated as they are never that close.. You wouldnt think with that many bends its operate but its SMOOTH and a big Thanks to my fellow Posters- Top
Here it is if you still can't find it .
JimAttached Files- Top
Neil,
I hate to disagree , but Wayne called out the page , and I sent you a copy of it !
Jim- Top
You ARE 100 % Correct I Neglected to LOOK Closely at it My apologies It was so small that I thought it only Showed Non AC Vent... Just now I Zoomed in and see you were Correct.....Thus I have Routing Down but one poster said Cable Clip Never was used in C60 but LOOKS like it in Your Posted AIM page.. Ill go with thie AIM unless you know diff Thanks Again for Posting PIX and calling this to my attention...- Top
Neil------
If you need a "working copy" of a page of the AIM, remove the page, make a copy, and return the page to the AIM immediately. Use the "working copy" in the garage or shop.In Appreciation of John Hinckley- Top
