1970 Light Saddle "marbled" coloring- How to duplicate? - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4536
    I have a reproduction 1970 Light Saddle front console (I think from Corvette America) with different coloring than my original dash and console. It's a long story, but I'm stuck with it.
    The original console and dash are light saddle in color on the higher surfaces of the vinyl's texture, and darker brown in the lower recesses of the texture.
    The reproduction console is also light saddle in color on the higher surfaces of the texture (within a shade or so of the original), but a lighter tan in the lower recesses of the texture. (See photo; I don't know why it's sideways but it shows the original dash and reproduction console next to each other).
    Can anyone recommend a source for a reproduction 1970 Light Saddle console with light/dark "marbling" like the original?
    Alternatively, in an attempt to better match the original coloring, does anyone have a technique for dying the lower recesses of my reproduction console darker brown, while leaving the higher surfaces its current color?
    Thanks again folks! Isn't this hobby fun?
    Last edited by John W.; September 21, 2015, 02:27 PM. Reason: Deleted corrupt graphic
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Mark E.
    • April 1, 1993
    • 4536
    Re: 1970 Light Saddle "marbled" coloring- How to duplicate?
    The "Insert Image" didn't work in the first post, so I'm using "Attachments" to add the photo.
    Hope this works.
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Russ S.
      • April 30, 1982
      • 2162
      Is the original really suppose to look like that? I don't recall seeing them like that.
      • Kenneth B.
        • August 31, 1984
        • 2087
        My FEB. built 1970 light saddle original interior is ALL the same light color & dos NOT have the dark recesses. I have never saw one that did.
        • Michael W.
          • April 1, 1997
          • 4290
          The marbling is the result of many years of dust, dirt etc. Not original.
          Your picture is sideways as that's how you were holding your phone at the time.
          • Mark E.
            • April 1, 1993
            • 4536
            I don't know guys; I think the car is telling a different story.
            The sections of vinyl on the underside of the original console that were mostly shielded from sun, wear and dirt (third photo below) appear similar to the exposed dash surfaces (first two photos). This coloring looks much different than the repro console coloring shown in my prior post.
            Is my '70 Light Saddle interior really the only one like this?
            Mark Edmondson
            Dallas, Texas
            Texas Chapter
            • Leif A.
              • August 31, 1997
              • 3627
              Mark,
              I owned a '72 Warbonnet Yellow/Saddle car and that interior looked nothing like your pictures. The coloring was consistent across the entire surface...seats, dash, console, door panels, etc. The coloring was darker than what your pics show, as well.
              Leif
              • Bill C.
                • July 15, 2007
                • 904
                looks to me like it was redyed at some point and it is wearing out.
                corvette America will dye certain parts before selling them
                they do this with the door pulls and I be willing to bet on lots of other parts too.
                chesper than making twenty colored parts instead of five or six
                i have never seen anything like that on light saddle interior before
                • Mark E.
                  • April 1, 1993
                  • 4536
                  Originally posted by Leif Anderson (29632)
                  Mark,
                  Leif,
                  1970 Light Saddle, code 418/424 is unique to that year and is significantly lighter than code 417/421 Saddle from 1972.
                  Mark Edmondson
                  Dallas, Texas
                  Texas Chapter
                  • Mark E.
                    • April 1, 1993
                    • 4536
                    I really don't think so, Bill. This marbled pattern is too uniform, even on tucked-away surfaces as shown in my last photos. It doesn't look worn; it looks like it was made that way.
                    Any suggestions who I may talk to about this?
                    Mark Edmondson
                    Dallas, Texas
                    Texas Chapter
                    • Russ S.
                      • April 30, 1982
                      • 2162
                      What it looks like to me is that someone has washed the top finish off with a solvent like lacquer thinner.
                      [ATTACH=CONFIG]63906[/ATTACH][ATTACH=CONFIG]63907[/ATTACH][ATTACH=CONFIG]63904[/ATTACH]
                      • Russ S.
                        • April 30, 1982
                        • 2162
                        Try talking to Al Knock.
                        • Mark E.
                          • April 1, 1993
                          • 4536
                          Russ, if you look at the third photo above, it shows a section of "virgin" vinyl that was protected under the console. The two-tone marbling pattern is similar to the rest of the interior's vinyl. I doubt solvent was applied in this obscure area.
                          Mark Edmondson
                          Dallas, Texas
                          Texas Chapter
                            • 3415
                            Hi Russ,
                            Is it possible that somehow over the years the coloring agent in vinyl 'migrated' and is condensed in the darker areas?
                            Is there any correlation between the 'texture' of the vinyl and the dark areas? Is it in the 'low' areas of the texture?
                            • Mike E.
                              • February 28, 1975
                              • 5138
                              The green/light saddle 70 convertible I owned was an original interior car, and there was no similar marbling in that vinyl, I'm sure.
