1954 Tachometer - NCRS Discussion Boards
1954 Tachometer
  • Harold W.
    • March 1, 1977
    • 59
    1954 Tachometer
    My 1954 tachometer cable broke, and I bought a replacement, which also broke. It turns out the tachometer is jammed. Is it possible to remove the tachometer from the dash without removing the radio? It's been awhile since I have been under the dash. I searched the other threads, and didn't find any comments on this subject.
    Thanks, Harold Wrede (1322)
  • Eric F.
    • June 30, 2003
    • 319
    Re: 1954 Tachometer
    The top of the tachometer housing is flat, most likely to allow easy removal. After loosening the mounting screws the rear of the tachometer should drop down and allow you to slide it out without interference from the radio.
    Eric
    • Harold W.
      • March 1, 1977
      • 59
      Re: 1954 Tachometer
      Eric,
      Thanks for the quick response. Looks like it's fairly easy, and so I'd better get moving.
      Harold
      • Chris S.
        • January 1, 2000
        • 1067
        Re: 1954 Tachometer
        yes you can - loosen the cable - remove the bulb/wire - remove the two nuts and lock washers
        it will come out.
        1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
        Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
        1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
        1957 Corvette - FI 3 sp - Black and Silver
        • Harold W.
          • March 1, 1977
          • 59
          Re: 1954 Tachometer
          I got the tachometer out with only a few head "bumps". The shaft would turn with a wrench on it, but was very stiff. I took it apart and got the shaft freed up with AeroKroil. I cleaned the gears and put a little grease on them, as there was some there before, though pretty dry. It's back together, but the "hand" won't stay in the correct position. Do you know if there is a special mounting procedure, or do I use a dab of Superglue or Loktite to keep it in position. When I took the hand off, it came off the very thin copper colored shaft that is connected to the spring/flywheel gizmo. There does seem to be a spline under the hand, but that is not where it came apart. Any help or pointers would be appreciated. Thanks, Harold
