Replacement bolts - NCRS Discussion Boards
Replacement bolts
  • Justin S.
    • July 3, 2013
    • 305
    Replacement bolts
    Removing the front and rear suspension I'm finding bolts that are rusty and would like to replace them. Which company is the best at supplying bolt kits such as a-arm bolts, swing arm bolts etc.?
    Justin
    • 43247
    Re: Replacement bolts
    Justin
    Justin-------
    If the bolts have only light surface rust, you can clean them up with a wire wheel and re-use. However, if the corrosion has proceeded to the point that ANY of the threads or shank is eroded away, then they need to be replaced. Paragon and their dealers usually supply appropriate hardware.
    • Rich P.
      • January 12, 2009
      • 1361
      I would suggest making sure you keep and label all of the bolts you take off from whatever position so when you get new ones you can match them up to see if there correct. Many of the ones you get from the supply houses are generic in fit general years and may not be specifically correct for your year and application.
