69 battery cables - NCRS Discussion Boards
69 battery cables
  • Roger D.
    • June 3, 2014
    • 180
    69 battery cables
    I have a 69 coupe build date C04. I am up to the part on my restore of installing the positive battery cable. I am not sure if I need the top post cable or side mount. My AIM appears to show side mount but is a early model top post. Vin#194379S703636. Trying to stay original for later possible judging.
    Thank You in advance.
    Roger
    • 15640
    Re: 69 battery cables
    My SWAG is you need a top terminal, but your copy of the 1968-69 TIM&JG will tell you the approximate change point from top terminal to side terminal. I wouldn't want to guess at that figure and you shouldn't either. Look it up and be right.
    • Roger D.
      • June 3, 2014
      • 180
      Thanks Terry, I forgot about the TIM&JG. I will check it out now.
      Roger
      • Roger D.
        • June 3, 2014
        • 180
        Yup, TIM&JG mentions top post up until about SN 22,081. Also shows color of brackets. I wonder if you can get a Delco top post battery to simulate original.
        • Leif A.
          • August 31, 1997
          • 3654
          Have you checked with Restoration Battery yet?
          Leif
          • Roger D.
            • June 3, 2014
            • 180
            I checked with Antique Batteries in Youngstown Ohio. They duplicate the type battery for vintage type cars. Battery was $260. I will know check Restoration Battery. Thanks for the tip.
            Roger
