C-2 M21 shift linkage adjustment - NCRS Discussion Boards
  • William G.
    • April 30, 1984
    • 96
    I was under my car tonight, having installed the engine and transmission earlier this week, and thought I had the tranny shifter arms and linkage the same as when I took the units out of the car. However, after hooking up the linkage, the shifter inside the car seems to be too far back, as though it is in second, or fourth gear and will not shift the transmission!
    Any thoughts and help getting things into the right position would be very helpful.
    Bill
  • Stephen L.
    • May 31, 1984
    • 3160
    Re: C-2 M21 shift linkage adjustment
    There are many threads on this subject at the bottom of this thread (SIMILIAR THREADS). Check them out and you will have an answer
