New carpet installation - NCRS Discussion Boards
  • Bruce A.
    • August 18, 2015
    • 29
    Can I install/bolt my seats direct over the new carpet and jute or do I need to cut slots in the carpet to allow the seat brackets to be bolted directly to the fiberglass pan? I do not have the old carpet as a reference.
  • Philip A.
    • February 26, 2008
    • 329
    Re: New carpet installation
    Bruce
    Search the archives, this has come up many times. There are photos of original carpets and sketches/diagrams. Bolting over and through the carpet is not NCRS correct.
    Phil
    • Joe R.
      • May 31, 2006
      • 1822
      Hi Bruce,
      What year? I believe the cut outs differ.
      Joe
      • Bruce A.
        • August 18, 2015
        • 29
        1967 Coupe
        • Jim S.
          • March 13, 2013
          • 360
          Originally posted by Bruce Angel (61502)
          1967 Coupe
          The cutouts do differ on 67's. Attached from 67 JG.
          • Bruce A.
            • August 18, 2015
            • 29
            Jim, if I understand the drawing correctly, there's no removal of carpet, only cutting to form a hinged tabs at all four corners of the seat(s)...correct?
            • Alan D.
              • January 1, 2005
              • 2053
              And while working on the carpet do not forget to make the correct cut at the accelerator rod area. Not sure of correct cut for 67, but most carpet I have seen have a lot of extra carpet in the subject area.
              • Jim S.
                • March 13, 2013
                • 360
                Correct, you cut the dotted lines but do not remove any carpet. The front 'flaps' hinge to the inside of the seat while the rear has two flaps on each rail. The flaps fold down over the bolts once the tracks are installed.
                • Bruce A.
                  • August 18, 2015
                  • 29
                  Jim, what resource are you referencing in your response?
                  • Jim S.
                    • March 13, 2013
                    • 360
                    The info in the 1967 5th Edition Judging Guide
                    • Bruce A.
                      • August 18, 2015
                      • 29
                      Thanks Jim. Where can I get a copy?
                      • Jim S.
                        • March 13, 2013
                        • 360
                        National Corvette Restorers Society! 1963-67 NCRS Technical Information Manual & Judging Guides - Where does 48 years worth of detailed Corvette research by the experts in the Corvette Hobby go? In these books!  NEW 1966 6th edition available NOW! NEW 1967 8th edition available NOW! Prices are based on the base edition in all black and white, the expanded editions with color covers, and the expanded editions with color covers and color
