62 Clutch return spring install - NCRS Discussion Boards
    • 6960
    Any tricks to install the monster return spring on a 62.
  • Jim D.
    • 2885
    Re: 62 Clutch return spring install
    It takes only a few seconds following the procedure in the ST-12 and using a crescent wrench as shown.
    • Frank D.
      • December 27, 2007
      • 2703
      Its actually an "over center" spring....folks are mistakenly intimidated by its girth...it comes off easy. As mentioned, the ST-12 procedure works fine if you place the crescent wrench as per the attachment and "rock" the Z-bar until you reach the 'sweet spot' and the spring will almost fall off.
        • 6960
        Guys thanks, Frank thanks for PDF
