Trunk Lid Emblem Removal on C5. - NCRS Discussion Boards
  • Gene T.
    • May 31, 1997
    • 78
    I need a recommendation on how to remove the Trunk Lid Emblem without damaging the surface of the lid of course.
  • Paul S.
    • June 30, 1982
    • 354
    Re: Trunk Lid Emblem Removal on C5.
    Tape around it with masking tape . Heat it up with heat gun or hair dryer . Then take a plastic bondo squegee and work it till it comes off.
    • Gene T.
      • May 31, 1997
      • 78
      Paul.......Thanks for your words of advice. I will try it soon.
      • Douglas L.
        • May 8, 2015
        • 181
        I've never tried it but I've heard using dental floss to remove adhesive applied emblems works well. Get it under the emblem and saw back and forth on it.
        • Gene T.
          • May 31, 1997
          • 78
          I tried the dental floss and did not seem to work properly for me.
          Gene
          • John D.
            • June 30, 1991
            • 874
            From the GM service manual:
            Procedure
            • Use a J 25070
            Special Tools
            J 25070
            • Gene T.
              • May 31, 1997
              • 78
              Thanks John for the advice. I have a heat gun that operates in that degree range. I have found it is much better to ask advice than to try a method and damage the paint surface.
              • Ken R.
                • August 31, 1980
                • 302
                The dental floss or fishing line are both good methods, safe also. Use a sawing motion to cut thru the tape. I wrap ends of line around couple of wooden dowels to hold while "sawing". Then use Goo Off to remove the sticky film remaining.
                • Gene T.
                  • May 31, 1997
                  • 78
                  John..... I used the 500 - 700 F heat gun and the removal came off fine when I pried the emblem with a kitchen spatula. I cleaned the old adhesive with "Goo Off" and then applied the new emblem using the "Blue Painter's Tape" as a guide for proper placement.
