1967 water temp issue - NCRS Discussion Boards
  • Ralph E.
    • February 1, 2002
    • 905
    Re: 1967 water temp issue
    Originally posted by Wayne Champagne (59162)
    Hello all, the problem has been resolved! The gauge was shorting out in the instrument cluster. All four nuts were loosened and then the gauge was 'tweaked' slightly in the panel, then the needle dropped down under 100. The nuts were tightened and all is well. The gauge now reads in the normal temperature range. The clearance tolerance must be very critical. Thank you to all posters who helped. Regards, Wayne
    Wayne, Glad you got your problem fixed. It is very helpful to all of us when someone posts results of their fix. Many times posters present a problem and get advice from this board but leave us all hanging in the dark not knowing how if they got the issue fixed.
    Again, glad you fixed your problem.
