'67 body shims - NCRS Discussion Boards
'67 body shims
  • Bruce A.
    • August 18, 2015
    • 29
    '67 body shims
    Should I use the square shims/washers or the "fork" type shims to level my '67 coupe?
  • Leif A.
    • August 31, 1997
    • 3651
    Re: '67 body shims
    Bruce,
    I could be wrong here (certainly wouldn't be the first time) but I believe all body shims are the square type with a hole in the middle. The "fork" type shims are used for front end alignment. Even though not correct for the rear alignment in '67, many use the "fork" type on the rear, as well, as they're much easier to install.
    Leif
    • Bruce A.
      • August 18, 2015
      • 29
      Re: '67 body shims
      Thanks Leif! I'll stick with the square shims.
        Re: '67 body shims
        Bruce -
        The fork-type shims are only used at the radiator support-to-frame location (and were originally welded), and they're different than the fork-type shims used for alignment on the upper control arm shaft-to-frame attachment. All of the other mount locations (from the #1 mounts at the base of the firewall rearward) use the square shims.
