1962 temp guage - NCRS Discussion Boards
1962 temp guage
  • Phil A.
    • April 30, 1982
    • 121
    1962 temp guage
    Replaced gage and sending unit with new ones gage doesn't work. Checked ground wire it's ok. What's wrong? Thanks in advance
  • Terry D.
    • May 31, 1987
    • 2696
    Re: 1962 temp guage
    Well did you try the old gage with new sending unit? It is a process of elimination. Does new gage work with old unit? Did old stuff work before replacement. Where did you get new stuff? If I could solve your problem without any info I would have bought that island and retired long ago.
    • John G.
      • January 1, 2006
      • 85
      Re: 1962 temp guage
      Quick check. Disconnect wire at sending unit, should read volts with key on. ckt runs from ign to gauge to sender.
      Good luck, John G
      • Michael H.
        • December 1, 1987
        • 730
        Re: 1962 temp guage
        Phil,
        If you ground the green wire at the temp sender you should peg the gauge all the way to the right, don't leave it on there for very long. My 67 had a restored cluster but my gauge read low like 140-150. I tried 4 different temp senders until I found the right one with low ohms reading like 115 ohms, now my temp gauge reads 180 when the water is at 180 with an IR gun. My other temp senders were reading higher about 144 ohms or more when the water was 180 and my gauge said it was 140-150.
        Mike
