Carter AFB vs Holley - NCRS Discussion Boards
  • Jim D.
    • 2884
    Re: Carter AFB vs Holley
    Mark, I have to agree. A properly set up Q-Jet is one of the best street carbs. around.
    • Frank D.
      • December 27, 2007
      • 2703
      Yes, they are.
      But - that wasn't the original question....
      • Michael J.
        • January 27, 2009
        • 7141
        #18
        • Mark E.
          • April 1, 1993
          • 4597
          #19
          Originally posted by Frank Dreano (48332)
          Yes, they are.
          You're right. But sometimes it's just fun to bloviate.
          Mark Edmondson
          Dallas, Texas
          Texas Chapter
          • Frank D.
            • December 27, 2007
            • 2703
            #20
            As long as it isn't bumptious bloviation !
            • Steven B.
              • April 11, 2012
              • 233
              #21
              I think it all comes down to the point about originality. As has been mentioned and championed by others, and although some have favorites, when working properly, all of the carburetors mentioned will do the job for which they were intended. I wouldn't hesitate to use any of the carbs discussed, and would be especially keen on using a particular carb if it were original to the car, but that's just me. That said, I think it is a matter of how important it is to maintain or return to original condition.
              • Joe R.
                • May 31, 2006
                • 1822
                #22
                For all you Carter carb lovers, a sad story………..
                http://blog.hemmings.com/index.php/2...ns/?refer=news
                Hi Michael,
                Thanks for the article! I was quite intrigued by it!!! I've lived in St. Louis since 1988, but had no idea the Carter factory was here. It won't be here much longer!!! I think I will use that article in our next NCRS STL chapter newsletter (I'm the editor). Can you or someone else tell me which Corvette years used Carter carburetors?
                Joe
                • Peter J.
                  • August 23, 2015
                  • 9
                  #23
                  Originally posted by Joe Raine (45823)
                  Hi Michael,
                  Joe
                  1955-65 Corvettes used carter carbs, in 1966 it became all holley although higher hp engines were using holleys in 1965
                  • Michael J.
                    • January 27, 2009
                    • 7141
                    #24
                    I see references that say the '53-'54 Blue Flame triples were Carter YH side-drafts.
                    Here's one that just appeared:
                    https://www.forums.ncrs.org/showthre...-after-rebuild
                    • Michael J.
                      • January 27, 2009
                      • 7141
                      #25
                      Actually in '64, my L76 has a Holley as original, that was the first Holley use IIRC.
                      • Jim D.
                        • 2884
                        #26
                        Nope. As posted above, the 53-54's used Carters as well as some of the C-3's with Q-Jets.
                        • Michael J.
                          • January 27, 2009
                          • 7141
                          #27
                          That's news to me, I had always thought Rochester made the Quadra-Jet.
                          • Jim D.
                            • 2884
                            #28
                            Carter made millions of Q-Jets under the GM license. They are identical to the Rochester Q-Jets except it says Carter on the side. I've rebuilt many of them. I've heard two stories as to why Carter made them. One was because Rochester couldn't keep up with the demand and another was that there was a fire at the Rochester plant (which could explain the first story).
                              Jim -
                              It was a demand issue - in the late 60's-early 70's, just Chevrolet Impala/Caprice volume was 6,000 per day (373 per hour), plus Chevelle, Camaro, plus Olds, Buick, Pontiac, Cadillac, plus Chevy and GMC trucks - that was a LOT of Q-Jet carburetors! There was no way in the world that Rochester could support that kind of volume, so Carter was licensed to build Q-Jets to cover the excess volume.
                              • Michael J.
                                • January 27, 2009
                                • 7141
                                #30
