'67 body mounts - NCRS Discussion Boards
'67 body mounts
  • Bruce A.
    • August 18, 2015
    • 29
    '67 body mounts
    Can you level/adjust a C2 coupe body by varying the torque values on the body mount bolts? I hear torque values ranging from 25 ft-lbs to 55 ft-lbs???
  • Keith B.
    • September 15, 2014
    • 1582
    Re: '67 body mounts
    I am no mechanical engineer but if you leave a bolt loose it will cause premature failure of the bolt. You level the body by using shims. I would torque the bolts to what the AIM calls out for
      • 43219
      Re: '67 body mounts
      Bruce--------
      Absolutely NOT. Period.
      • Domenic T.
        • January 29, 2010
        • 2452
        Re: '67 body mounts
        Bruce,
        If it's a front to back issue, I removed shims from the front to the back to balance the amount of shims when there were to many at the core support. They can also be moved side to side, but the spacing MUST be correct. I teetered my 67 when I had to many shims at the core and added shims to the rear where they didn't exceed the limits.
        DOM
