1963 rear strut rod heat shield - NCRS Discussion Boards
  • Jerry C.
    • November 1, 1995
    • 741
    Any body making these shields? Thanks in advance.
  • Bob R.
    • June 30, 2002
    • 1595
    Re: 1963 rear strut rod heat shield
    The original ones on my 63 broke off so I cut a small piece of sheet metal painted it black and stuck it on with some black silicon adhesive.
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's the heat shields on a January 1964 car.
      • Joe R.
        • July 31, 1976
        • 4550
        Great pic Wayne! Those are held by three spot welds on two of the edges. Not a problem for any welding shop or auto fabricators.
        JR
          • 43221
          Jerry-------
          Easily fabricated and spot-welded. So easily fabricated, in fact, that reproduction sources might be embarrassed to offer them.
          • Dan H.
            • July 31, 1977
            • 1369
            Was wondering how far into 64 production one would expect to see these shields?
            Dan
            1964 Red FI Coupe, DUNTOV '09
            • Gene M.
              • April 1, 1985
              • 4232
              I seem to see more cars without these little square welded on sheet metal than one's that do. Was this hit and miss or do they just break off? I'm assuming these were welded on after the cams and strut rods were assembled. Yes, no?
              • Joe R.
                • July 31, 1976
                • 4550
                That's a no. They were spot welded to the camber support assembly.
                JR
                  • 43221
                  The deletion of the shield from the strut rod bracket was not accompanied by a change of part number. Apparently, it was changed simply by a revision to the specs for the part.
                  • Jim L.
                    • September 30, 1979
                    • 1808
                    So only '63 and perhaps early '64 brackets were manufactured with the shields? When the shields were deleted, was that accompanied by a re-routing of the exhaust pipes to get the heat away from the camber rod bushings?
                    • Gene M.
                      • April 1, 1985
                      • 4232
                      JR
                      The ones I have seen look more like a tack weld done with a mig or a tig weld.
