1964 L84 camshaft question - NCRS Discussion Boards
  • George C.
    Infrequent User
    • January 1, 1994
    • 3
    Can someone advise me as to a currently available correct replacement camshaft for a 1964 L84 F.I. engine, and who might carry it? Thanks for any enlightenment on this subject.
    George
    • 43271
    Re: 1964 L84 camshaft question
    George
    George-------
    Assuming you're wanting the exact original camshaft, GM #3849346, Crane used to make it under their part number 967251. I don't know if they still do, though.
    • John D.
      • December 1, 1979
      • 5507
      Hi George, I believe I might have given you this info.
      Part # CS118R Lifters AT992. Sold by Federal Mogul. The CS118R is the 30-30 cam. The CS113R is the 097 cam so make sure you get the right one. John D.
      • George C.
        Infrequent User
        • January 1, 1994
        • 3
        Hi John;
        Yes you did give me the info previously-I seem to have lost it and couldn't remember what you told me! Thanks; I'm printing it out this time. Finally getting engine back together. George C.
        • George C.
          Infrequent User
          • January 1, 1994
          • 3
          George-------
          Thanks, Joe- I appreciate the help.
            • 15706
            For years I've recommended replacing the torque-shy 30-30 cam with the LT-1 cam (Federal Mogul/Speed Pro CS1145R), and no one has ever been disappointed - more low end torque and about the same top end power and idle behavior.
            If you want "more power" massage the heads and you'll have close to 300 SAE corrected RWHP, and a useable power bandwidth to 7200 using the second design SB valve springs (Federal Mogul/Sealed Power VS-677).
            I call the configuration "327 LT-1"... lots of discussion here and on the Corvette Forum with all the system engineering analysis and both lab and chassis dyno tests.
            And don't forget to replace those spindly, prone to failure, early 327 connecting rods with a set of Eagle SIR5700 rods. For about 250 bucks it's the cheapest insurance policy you'll ever buy.
