A/C radiator fan for 67 - NCRS Discussion Boards
  • Domenic T.
    • January 29, 2010
    • 2452
    I did a search and found no info on the size of the radiator fan for the 1967 BB. I also looked at what the vendors have and they specify A/C or except A/C on other C2 years but only 171/2" with more pitch for the 67 and only have one available.
    Did the 67 only have one fan for non A/C and A/C?
    I have a SB 64 Fan on the car now but it is a fraction away from the shroud. I put the shims under the engine mounts and twisted the engine to my advantage with the oblong mounting holes but I need the smaller fan. Can't start my frame up resto till this is solved.
    Dom
    Re: A/C radiator fan for 67
    Dom
    Dom -
    '67 small-blocks had one fan without A/C (#3770529, 5 blades, 17-1/8" dia.), and two others with A/C (#3789562 or #3863137, 5 blades, 18" dia.)
    There was only one fan (#3888366, 5 blades, 17-1/2" dia.) for big-blocks, with or without A/C.
    More detail on all fans in the Chassis section, 5th Edition '67 TM&JG, page 174.
    • Domenic T.
      • January 29, 2010
      • 2452
      John,
      Thanks, that clears that up. The 18" I have on the 67 came out of my 63 hope chest. I was hoping I could use it till I ran across the correct fan. When I bought the 67 in 1971 it was wrecked and the fan was toast. Guess I'll have to bite the bullet and buy a repo.
      Dom
      • Keith B.
        • September 15, 2014
        • 1604
        Dom BB passenger cars used the same fan with a clutch fan set up I found one for dads 67 BB with AC for 50 bucks at a swap meet. It seemed to pass at a regional. Good luck
