Preamble: I had a very disappointing and discouraging day yesterday. A true showstopper. When restoring 50 year old cars, we sometimes forget that pitfalls are common. Salvaging old correctly cast numbered and dated objects can be rewarding, yet sometimes it gets nightmarish. I have one of these situations at hand. I'm sorry this is long, but it is complicated and need details explained.
I have a major task ahead and would invite input and advice. Unfortunately, after machining the intake manifold and trying a few bolts to fit the heads on this 427 engine build, it appeared something was wrong. When I took the engine back from the shop I thought I was ready for final assembly, paint, and installation. I only tried a few intake bolts at the engine shop and had a little trouble but figured I'd be okay. It was late so I took the engine home and I figured the rest would be easy after a good nights rest. Not so.
I acquired these dated heads as the mounted heads on the running engine were dated beyond the car build(by one day). Since we were rebuilding the powerplant to stock, it was decided that now is the time to get correctly dated heads. Even though the dates are covered up by the valve covers, authenticity is still always a factor. Knowing the "right stuff" is "undercover" is important to me.
I knew they would need rebuild, as evidenced by the discovery of needing new valve guides and a valve regrind, etc, and was told all intake threads were made up of threaded inserts. I bought the heads. I actually welcomed the threaded inserts as the threads on other heads I've seen had issues with stripped threads. However, little did I realize that there was a major problem lurking that everyone missed...... the seller(allegedly), the machinists, and of course....me.
When I got them in I rushed them to the machine shop for rebuild. Lesson learned. AGAIN!
Here you can see with all bolts inserted that there is a problem. All of them are varying angles in ALL directions....front to back and side to side. Now it's quite obvious, that whoever did this had no clue as to what they were doing. It was clearly a rookie mistake and the party had no business attempting this task. The heads were used and ran at one point.
I took some measurements on the original head with stock threads using a 3/8-16 straight long threaded rod and a small machinists protractor. It appears the angle of the stock threads with respect to the intake mating deck are approximately 75 degrees. If anyone can confirm the actual specification for me I would appreciate it.
Using the threaded rod I measured the replacement heads. I get approximately 85 degree angle. Some are more and some are less.
Here is a example using my rough measurement. The angle line tracing of the rod on the left is "stock". The angle line on the right is these heads with the previously(incorrectly) installed 3/8-16 thin-wall inserts.
Stock apx 75* angle ------- Improper head(s), apx 85* angle. (ignore the pencil 70/80, it should be 75/85)
Additionally, looking very closely on some locations I can see the original threads and bottom of the original hole. Clearly obvious when looking down deep. Some bolts bottom out on the original ledge left by the incorrectly angled inserts.
Here is my plan and welcome your thoughts. The present inserts are 0.505 OD(measured). I did some research and they appear to be "Thin Wall" inserts.
I found "Heavy Wall" inserts here made by EZ-LOK. These are 9/16-12 external thread size and use a 31/64 tap drill.
Also available are "Extra Heavy Wall" thickness here. These are 5/8-11 external thread size and use a 17/32 tap drill.
I am leaning to use the "Extra Heavy" part. However, I have concerns....
After removing the incorrectly installed inserts, re-drilling may be difficult to achieve the correct 75* angle without loosing some OD wall thickness.
Another concern is there are 4 of 8 (IIRC) blind holes in each head. 4 pass through to the pushrod/rocker area. The others are unknown. I am concerned about the risk or drilling into the water jackets at the sides of the insert area. Depth can be controlled easily, but the width is fixed by the insert drill size. Edit...I just checked and there appear to be NO blind holes near water jackets.
I spoke with my machinist late yesterday and he agreed this plan should work, albeit with concerns above. He is ready to set up his Bridgeport to help me repair these heads. Of course I have to disassemble them from the block and protect them with wrap for shavings intrusion.
Any thoughts or concerns about my plan for repair is welcomed. Please keep in mind I have now milled a 3x2 intake manifold to fit this assembled engine and am committed to use these heads at this time. These are not "throw away" items. I must succeed and ask for your advice.
