L36 discoveries - NCRS Discussion Boards
L36 discoveries
  • Douglas L.
    • May 8, 2015
    • 181
    L36 discoveries
    Took the oil pan off my 68 L36 today and found a couple of odd things. First off, to my surprise it has 4 bolt mains and secondly, to my even greater surprise, cast crank!
    It definitely has been rebuilt(someone installed forged pistons and spent a lot more time on a balance job than GM would have) so the crank could easily have been replaced but the block has a appropriate casting date for the car and a pad stamp that looks good to me. I had heard that some L36/L68s had 4 bolt mains but thought they all had forged cranks.
    Anyhow, I was somewhat surprised and thought I'd share the info.
    • January 31, 1988
    • 43198
    Re: L36 discoveries
    Douglas-------
    Some 68-69 L-36 or L-68 did have 4 bolt mains. However, 4 bolt mains could also have been added. This is quite easy as the same block casting was used for either 2 bolt or 4 bolt finished blocks. The tappings above the oil filter will usually tell the tale of whether the block was an original 4 bolt as folks rarely drill and tap the bosses when they install 4 bolt mains.
    What is the casting number on the crankshaft?
    • Douglas L.
      • May 8, 2015
      • 181
      Re: L36 discoveries
      Joe,
      It does have the drilled and tapped oil cooler bosses. I remember reading in the GM high performance book that all 4 bolt blocks
      had drilled and tapped bosses but always wondered if it was true.
      The crank # is 3804815NF. I heard that Chevy started putting cast cranks in the more pedestrian big blocks in 68 and remember from my Oldsmobile days that 68 was the first year for cast cranks for pretty much all engines for them(even W-30) but the consensus seems to be the L36 and L68 retained their steel cranks up until 69.
        • January 31, 1988
        • 43198
        Re: L36 discoveries
        Joe,
        Douglas------
        GM casting #3804815 (or, 816) is a cast 3.76" stroke crankshaft. The "NF" (nodular ferris) absolutely confirms that. I believe it's probably original to the engine. I could never figure out where this casting number comes from, though. This number implies a first use for 1962. Of course, no Mark IV big blocks were being produced anywhere near that early.
        I seem to vaguely recollect that L-36/L-68 with cast cranks are usually found with 4 bolt mains.
        Believe it or not, back in the late 60's big block cast SERVICE cranks actually cost slightly more than the SERVICE forged cranks, including the L-88 crank.
        • Larry E.
          • November 30, 1989
          • 1665
          Re: L36 discoveries
          Douglas------
          Joe: NASCAR mystery engine was about that time--1963 Daytona Pole by Jr. Johnson. IIRC--Larry
          Larry
          LT1 in a 1LE -- One of 134
          • Larry E.
            • November 30, 1989
            • 1665
            Re: L36 discoveries
            1963-1963-chevrolet-impal-10_800x0w.jpgFWIW: Here is a picture of the "mystery" engine.
            Larry
              • January 31, 1988
              • 43198
              Re: L36 discoveries
              Larry----
              The "mystery engine" was a Mark II big block. I believe it used a crankshaft more like the Mark I ( 348 409).
                • December 31, 1992
                • 15633
                Re: L36 discoveries
                Nodular cast iron is a very strong, tough, and durable material - almost as good as typical medium carbon forging steels and more than adequate for a road engine that will only see 6000 revs occasionally.
                Nodular cast iron is a quantum leap above gray cast iron.
                I think Chevrolet began producing nodular iron cranshafts beginning in 1967 or '68. The '67 350 may have been the first and other low to medium performance engines followed. Pontiac and Olds may have started using nodular cast iron a few years prior.
                  • January 31, 1988
                  • 43198
                  Re: L36 discoveries
                  Duke------
                  I agree. Cast iron crankshafts are often maligned but they are more than adequate for virtually all street applications. Between 1970 and 1997, forged steel crankshafts were used only for LT-1, L-82, and LS-6 engine applications.
                  • Bill L.
                    • January 31, 2004
                    • 1403
                    Re: L36 discoveries
                    Duke------
                    Pretty sure the 69/70 L46 had the forged steel crank as well.
                    Bill
                      • January 31, 1988
                      • 43198
                      Re: L36 discoveries
                      Bill
                      Bill------
                      Yes, it did. I should have said between 1971 and 1997.
                      Actually, the L-82 was an L-46 with 9:1 compression. Strangely, when the LT-1 dropped from 11:1 to 9:1, the LT-1 RPO remained the same. However, the same thing didn't happen with the L-46. Most likely, this was because 2 years elapsed between the death of the L-46 and the birth of the L-82.
                        • December 31, 1992
                        • 15633
                        Re: L36 discoveries
                        Duke------
                        I think when most guys hear "cast crank" they think of gray iron even though most cast cranks have been nodular iron for nearly 50 years. I'm surprised that GM continued to use a forged, Tufftrided crank in the low compression single catalyist L-82. IIRC the tach redline was less than 6000 and they didn't make useable power much beyond 5500.
                        But the tooling was probably fully amortized, so no investment was required to continue with the forged crank for that one low volume application, and I expect they sold relatively well over the counter to guys who were building souped-up 350s.
