1967 - Battery Orientation on 327/350 with AC - NCRS Discussion Boards
  • Bill C.
    • July 15, 2007
    • 904
    just a quick question...
    when the battery is correctly installed, are the battery posts on the fender side or steering column side?
    currently its with the posts on the fender side, but I find it extremely hard to use the quick disconnect. hard as heck to reach around the back etc...
    thanks in advance.
    bill
  • Jim T.
    • March 1, 1993
    • 5351
    Re: 1967 - Battery Orientation on 327/350 with AC
    i owned a 1964 with factory air conditioning in 1968-1969 but do not remember where the positive battery cable is attached to the frame. I disconnect the negative battery cables from the frame of my 1968 and 1970 Corvettes when I am not going to drive them, it is so easy.
    • Jimmy G.
      • November 1, 1979
      • 977
      Steering Column
      • Larry M.
        • January 1, 1992
        • 2703
        Positive post (+) is closest to the firewall and negative terminal (-) is closest to the windshield washer bag. Disconnect goes on the negative side of the battery.............it is not difficult for me to access.
        My car is also a 1967 327/350 HP with factory AC.
        Larry
        • Leif A.
          • August 31, 1997
          • 3657
          Larry
          Larry is absolutely correct. Be sure you have a Group 24 battery and not a Group 24F...the terminals are reversed.
          Leif
          • Bill C.
            • July 15, 2007
            • 904
            thanks for the great info...
            i may have the wrong battery in the car.
            which is why the top posts are on the fender side, not the steering column side.
            will let u all know tomorrow.
            bill
            • Bill C.
              • July 15, 2007
              • 904
              hey--
              i have the correct battery, it was just put in the car incorrectly.
              took 5 minutes to fix up and all is good.
              thanks for all the input from everyone.
              bill
