C2 C3 Original Thermostat Temperatures - NCRS Discussion Boards
  • Mark E.
    • April 1, 1993
    • 4600
    Three thermostat temperature questions:
    1- What temperature thermostats did C2 and C3 cars come with? Did it vary by year, engine, or if A.I.R., NA9 equipped? Joe posted earlier that "All 1968-69 Corvettes were originally equipped with 195 degree thermostats. This was connected to the fact that all 1968-69 Corvettes were equipped with AIR", but I couldn't find info for other years and options.
    2- Is the indicated temperature the thermostat opens checked during PV?
    3- Are there any data supporting an engine running at 160 degrees instead of 180 or 195 produces more power? Back in the day, I would install a 160 degree thermostat to improve performance (the belief was that a cooler running engine => cooler intake => more dense air charge => more power). Other than maybe some cold weather driveability (not an issue in Texas, especially for hobby cars), any downside to running at 160 degrees?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
  • Keith B.
    • September 15, 2014
    • 1588
    Re: C2 C3 Original Thermostat Temperatures
    Mid years with out K19 got a 180. K19 cars used a 195. A t-stat controls minimum tempture ONLY. once it reaches its stated temp it opens. Thats all it does.
    • Larry M.
      • January 1, 1992
      • 2701
      Agree with Keith on thermostats for C2 cars.
      During PV, the operating temperature will be checked, so a 160 thermostat may cause a problem. It probably will, unless PV is done during the summer time in the heat of the day. Then the car engine temperature may be higher due to limited radiator heat capacity/removal.
      I also ran a 160 thermostat in my performance cars back in the day. But I also changed oil very frequently, so the lower temperature of the oil and the residual moisture were not issues. Engine oil needs to be around 190-200 F (or more) to boil off the moisture that accumulates due to combustion. I also lived/worked in SE Texas during this time.
      I personally believe that the SB Chevy engine runs best overall with a 180 F thermostat. That is all I use now.
      Larry
      • Jack M.
        • March 1, 1991
        • 1181
        Mark- There is some thermostat data available in the "Information Kits' provided by the GM Heritage Center.
        For 1966 (in the Cooling System section), I find the following:
        THERMOSTAT
        Type: Pellet
        Begins to Open at: 177*-182*F
        Fully Opened at: 221*F
        For 1968-69, I find the following:
        THERMOSTAT
        Type: Pellet
        Begins to Open at: 192*-198*F
        Fully Opened at: 217*F
          • 43248
          THERMOSTAT
          Type: Pellet
          THERMOSTAT
          Type: Pellet
          Jack-------
          Many C3 Corvettes with CCS emission control system (no AIR system) used a 180 degree thermostat.
          I prefer a 180 degree thermostat for ALL Corvette applications except computer-controlled applications originally using a 195 degree thermostat.
          • Jack M.
            • March 1, 1991
            • 1181
            Good to know, Joe. I was mainly illustrating the operating range reported in those documents.
            • Mark E.
              • April 1, 1993
              • 4600
              Thanks guys.
              In summary, it looks like the consensus is:
              - Mid-years w/o A.I.R ==> 180 degree thermostat
              - Mid-years with A.I.R ==> 195 degree
              - 68-69 ==> 195 degree (Joe earlier commented all of these cars had A.I.R)
              - "Many C3s" w/o A.I.R ==> 180 degree thermostat
              Is there more definitive information for 70 and newer C3s?
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
